Feature Request - Define Action Toolbars Navigation
Posted: 16.08.2023, 16:55
by robsc
When you're using the "Define Action Toolbars" window, it would be helpful if clicking on a toolbar icon in the left window pane would automatically navigate to the corresponding button in the right window pane. This would make it simpler to locate and access a button if you forget or don't know what it does, and make the full description more readily available.
Can images be added to posts? I attempted to upload one to Dropbox and insert it using the provided button, but the preview didn't show the image, so I'm unsure if it's allowed.
Re: Feature Request - Define Action Toolbars Navigation
Posted: 16.08.2023, 17:55
In 893 description is available also in the left pane.
Workaround for previous versions, use a quick filter to find the action easily.
Dreamer wrote: 27.09.2007, 23:18- Sometimes it's useful to make a screenshot of the problem. You can use the integrated FreeCommander feature (menu > Tools > Desktop Snapshot), or one of many free tools available on the Internet, or just the integrated Windows feature - press PrintScreen to make a screenshot, then open any image editor, e.g. Paint, press Ctrl+V to paste, save it and upload it to
https://postimages.org/ , or
https://imgur.com/ for example. Do not place large screenshots in the forum, use the links, or thumbnails instead. Please use the English language for screenshots, you can use /Lng=English command line parameter.
- The donor can send the request for upload possibility via
e-mail.
Posted: 25.08.2023, 21:43
by robsc
Oh... I see now. Thanks for letting me know it gives you the whole description. I wasn't aware.
