Renaming parent folder indicator is semi-possible
Posted: 18.08.2023, 09:59
To recreate this select
Tools > Settings > File/folder operations > Rename/Create > Use dialog window for rename
Tools > Settings > View > File/folder list > General > Show parent folder ".."
Tools > Settings > View > File/folder list > Mouse shortcuts > Click with right mouse buttons [...] > Folder: icon > Rename
and then right click on the icon of the parent folder
The Rename window should should up with
in the New name box - attempt of renaming which will result with an error
Renaming for this folder should be either disabled - or made possible by showing the real name instead of placeholder and combined with refreshing of the path in the Address Bar
I am using FreeCommander XE 2023 Build 893 64-bit Donor Portable
..Renaming for this folder should be either disabled - or made possible by showing the real name instead of placeholder and combined with refreshing of the path in the Address Bar
