Last character in Name of an Item within Favorite Toolbar cannot be a sign of space
Posted: 04.09.2023, 15:54
It is impossible to have two Items with the same Name in one Favorite Toolbar. That is logical
But it is also nearly impossible to try to workaround this by adding a whitespace character an the end of a doubled Name. I mean: I can e.g. make an Item for the Left Panel like this
Name:
Test Name
Program or folder:
C:\My Portables\FreeCommander\FreeCommander.exe
Parameter:
-T -C -L="C:\Test Folder"
and its Right Panel doppelganger
-T -C -R="C:\Test Folder"
by giving it a Name like this
Test Name_
[where the >>_<< sign represents a whitespace because this forum will not allow to show it] and then OK it - but the >>-R<< Parameter will get turned into >>-L<< if that whitespace [represented here by that >>_<<] is
● U+0009
● U+0020
● U+00A0
but not when it is
U+2000
according to the list available at https://en.wikipedia.org/wiki/Whitespace_character. This ability / inability must of course go further down that list of white space versions- but I simply just stopped when I hit the first sign that allowed me to trick FC into accepting an invisible [i.e. space] sign [that U+2000 version]
And there is also this probably related bug: https://freecommander.com/forum/viewtopic.php?t=13555
I am using Build 894 64-bit Donor Portable
