Page 1 of 2
Size on disk info for Status Bar
Posted: 20.09.2023, 11:21
Under the
Tools > Settings > View > Status Bar > Content > Define Details > Text Pattern
and
Tools > Settings > View > Status Bar > Content > Define Details > Hint Pattern
user scan utilize
[fc_sizeAutoSel]
[fc_sizeSel]
[fc_sizeKBSel]
[fc_sizeMBSel]
to see info about the real size of selected items
But what about size on a given drive, i.e. in accordance to its allocation unit size?
I think there should be separate codes for that ["size on disk" as it is described in Windows Explorer], something like
[fc_sizeAutoSelAlloc]
[fc_sizeSelAlloc]
[fc_sizeKBSelAlloc]
[fc_sizeMBSelAlloc]
perhaps?
Re: Size on disk info for Status Bar
Posted: 20.09.2023, 14:00
What about existing [fc_sizeOnDisk...]?
Posted: 20.09.2023, 20:59
It seems that this is currently not working.
Posted: 21.09.2023, 10:02
Are you merely taking an aducated guess here - or were you actually using this variable in the past?
I get zero results when I search for "fc_sizeOnDisk" [https://www.google.com/search?client=fi ... eOnDisk%22, https://duckduckgo.com/?t=ffab&q=%22fc_ ... %22&ia=web, https://www.bing.com/search?q=%22fc_siz ... cc=0&ghpl=]
Posted: 22.10.2023, 17:23
Karol wrote: 20.09.2023, 20:59 [...]
Forez wrote: 21.09.2023, 10:02 Are you merely taking an aducated guess here - or were you actually using this variable in the past?
Well?
Posted: 23.10.2023, 20:54
You can select from the popup menu the "Size on disk ..." items.
The info "Size on disk..." is showed only if the column "Size on disk..." exists.
Posted: 24.10.2023, 14:53
Yes I can, thank you
But why does it need to have SizeOnDsk Column turned on in order to be able show such on disk size?
Posted: 24.10.2023, 21:04
Providing information about the allocated memory on the hard drive slows down data loading.
Most users don't need this info.
Posted: 24.10.2023, 21:40
OK, I have added option to define in the freecommander.ini (next release):
AlwaysLoadFileAllocatedMemorySize=0
If you want always load the size, change the line to
AlwaysLoadFileAllocatedMemorySize=1
Posted: 24.10.2023, 23:39
Will this be an equivalent of turning on the Size of folders option, which option when used shows the size of folders in the Column named Size Auto?
Posted: 06.04.2024, 12:42
Has this been implemented?
I get zero result when I search for
within files of
C:\Users\YOUR-USER-NAME\AppData\Local\FreeCommanderXE\Settings
Posted: 06.04.2024, 14:28
by horst.epp
Forez wrote: 06.04.2024, 12:42 Has this been implemented?
within files of
This entry definitely exists, at least for me
Posted: 06.04.2024, 14:53
In the FreeCommander.INI file? In what section of it?
Posted: 06.04.2024, 16:32
Section:
[Form]
You can just close FC and add it there manually, at the end of the list.
Posted: 06.04.2024, 16:38
by horst.epp
Forez wrote: 06.04.2024, 14:53 In the FreeCommander.INI file? In what section of it?
[Form]
