Yellow triangle with exclamation mark in Search window
Posted: 21.09.2023, 16:22
by funkist
I just noticed, I have this triangle sitting in the lower right corner of my search window:
It's there as soon as I open the search window and does not change, even after successful or unsuccessful searches. It does not show any hover text.
Update: it's not related to Quick Filter either.
Does anyone have an idea what it means?
Thanks - fk
Re: Yellow triangle with exclamation mark in Search window
Posted: 21.09.2023, 17:45
Confirmed, with custom and default settings.
894 donor 64-bit, Windows 10 22H2 64-bit
Posted: 22.09.2023, 15:03
On Windows 10 Enterprise 20H2 x64 it is present in Build 894 64-bit Donor Portable - but not in Build 880 32-bit Public Installed
Posted: 22.09.2023, 22:34
The icon has no meaning, please ignore it.
Removed for the next release.
Posted: 22.09.2023, 23:20
What about the same icon here:
If I uncheck the checkbox, some points are not removed:
