Unable to locate two new features of build 899 [SOLVED]
Posted: 16.12.2023, 19:07
In the release info
https://freecommander.com/forum/viewtop ... 330#p42182 it says
- Implemented: New options for "Tab Management" added. Function "Last used tab (Ctrl+PgUp)" is configurable with: "Only tabs from active pane" and "Show quick filter for list filtering"
- Implemented: New option "Use recycle bin when overwriting" in the FreeCommander copy dialog (Settings tab)
I am unable to find these. What are the full paths for accessing them?
Re: Unable to locate two new features of build 899
Posted: 16.12.2023, 21:27
Tools-Settings-Folder Tabs: Tab Management tab
You need to set copy operation to "Use FreeCommander" under Settings-File/folder operations.
Try to copy with dialog, on the Settings tab in the copy dialog you can see the option "Use recycle bin when overwriting"
Posted: 17.12.2023, 00:07
Karol wrote: 16.12.2023, 21:27
I did not saw and still do not see the supposed "Last used tab" option
I did not saw and still do not see the supposed "Use recycle bin when overwriting"
And yes, I am sure, I am using the 900 x64 version
Posted: 17.12.2023, 00:59
Forez wrote: 17.12.2023, 00:07I saw and still do not see the supposed "Last used tab" option
"Define keyboard shortcuts" - "Change to last active tab", the option name is different, default shortcut is Ctrl+PageUp, toolbar button is available too.
Forez wrote: 17.12.2023, 00:07I saw and still do not see the supposed "Use recycle bin when overwriting"
Strange, also with default settings? I tested with default settings and it's there, Copy dialog, Settings tab, last option above the Save button.
Posted: 28.12.2023, 10:04
I have just once installed over the 900 x64, then uninstalled it and installed 900 x86. Each version did not had these two new options, even when I was running with default settings
And what Save button do you speak of? Are we even on the same page here? Where is this Save button on my screenshots?
Posted: 28.12.2023, 11:05
On your screenshot:
- Last used tab_result.png (52.32 KiB) Viewed 35498 times
Posted: 28.12.2023, 14:42
For the first one: I kept looking and lines right next to check boxes. Stupid me
That second one: it would have been possibly to locate for me had it been described not as being available
but described as
in the FreeCommander's pop up Copy window (its Settings tab) that shows up when attempting execution of coping process (if user has also chosen Tools > Settings > File/folder operations > Copy > Use FreeCommander)
Thank you for your help
