Status Bar size info lacks Bytes denotation
Posted: 07.04.2024, 09:58
Under the
Tools > Settings > View > Status Bar > Content > Define Details > Hint Pattern
users can choose what is to be shown when they will move the moue pointer over the Status Bar
But as you can see in this example
Status Bar - Bytes lacking.png (5.97 KiB) Viewed 222961 times
there is no description of units for bytes
I suggest then either changing what effect gives the
[fc_sizeSel]
or add a new one
[fc_sizeBSel]
and make it show the same data as the first one but with an added
 B
at its end
I am using Build 905 64-bit Donor Portable on Windows 10 Enterprise 20H2 x64 [10.0.19042]
Re: Status Bar size info lacks Bytes denotation
Posted: 19.03.2026, 00:26
Am I correct, that in Build 946 64-bit Donor Portable this has not been upgraded? That it is still impossible to see add a marker, which would indicate to user clearly that it the bytes that are reported in a string of numbers?
Posted: 19.03.2026, 18:49
Simply define the hint as
[fc_sizeSel] Byte(s)
[fc_sizeKBSel] KB
[fc_sizeMBSel] MB
[fc_sizeGBSel] GB
Posted: 20.03.2026, 08:17
Yes, a simple trick like this
[fc_sizeSel] B
does work - but nevertheless it is a workaround
But I reckon that this is then not a bug, but a feature?
