Thumbnails update propositions and bugs
Posted: 09.05.2024, 09:49
[Coming out from this discussion https://freecommander.com/forum/viewtopic.php?t=12162 and also from this https://freecommander.com/forum/viewtop ... 838#p35410 one]
I think there is a lot that can be improved for the utilization of Thumbnails in FreeCommander. Here is my list of various propositions and pin pointed issues:
#1] Easy / clear way to set up the default thumb size. Preferably in
Tools > Settings > View > Thumbnails
[and also keep there other below options]
#2] Choice for either remembering chosen thumb size for a particular path or always resetting it to default after navigating away from a folder in which size was changed
#3] Choice for either remembering chosen thumb size for a particular Tab or always resetting it to default after navigating to some other folder within that Tab in which size was changed
#4] Choice for either remembering chosen thumb size for a particular Tab or always resetting it to default after switching to other view mode in that Tab in which size was changed and then going back to utilizing once more thumbnails in that very same Tab [assuming user has not switched in the meantime to some other Tab]
#5] Ability to increase size of all thumbnails on the spot by pointing on an empty / margin space and using CTRL + Mouse Wheel Up / Down [or any other definable keys / buttons] being pressed at the same time. [And yes: there already is this option https://freecommander.com/forum/viewtopic.php?t=13813 but its not the same - what I am proposing is more like how zooming works in various graphic programs]
#6] Ability to display an enlarged version of a thumbnail when hoovering over a one in a vicinity of mouse pointer. And / or alternatively make the Mouse Wheel be able to zoom in and out a graphic file that the mouse pointer is hovering upon
(I reckon the above ones would require most coding to be done in order to be implemented in FC]
#7] Ability to display an enlarged version of a thumbnail when hoovering over a one- but not through the Quick View but by using a new Quick Large Thumbnail View feature: https://freecommander.com/forum/viewtopic.php?t=13820
#8] Dealing with this old issue of confusion concerning drop-down arrow menu: https://freecommander.com/forum/viewtopic.php?t=13819
#9] Dealing with this bug concerning Thumbnails feature context menu: https://freecommander.com/forum/viewtopic.php?t=13815
#10] Dealing with this newly spotted bug occurring when zooming using the Quick View feature: https://freecommander.com/forum/viewtopic.php?t=13817
