Build 908 - Check for Updates-Button is broken
Posted: 15.05.2024, 18:47
by andreas
Hi there.
Clicking on the button just does nothing. Or at least it didn't report that there is no update available.
64bit Release, Windows 11 24H2.
Re: Build 908 - Check for Updates-Button is broken
Posted: 17.05.2024, 11:50
by horst.epp
Not confirmed, check for updates works fine.
Maybe a problem with your unsupported Windows version which is not yet out at all.
- Screenshot - 17.05.2024 , 11_48_38.png (4.35 KiB) Viewed 23613 times
Posted: 17.05.2024, 22:43
by andreas
Didn't work on 2 systems, today it shows the "uptodate" notifications.
So something might have changed in the background?
24H2 is already shipped to OEMs, so you might guess its as final as windows can always be.
