layouts edit
Posted: 27.09.2024, 11:46
by giudansky
I'm not sure if it's a bug, but it's an annoying inconsistency.
the layout names in the "edit layout" window don't have names and it's hard to manage them.
Is it possible to fix it?
Re: layouts edit
Posted: 27.09.2024, 12:39
What is your program version?
In the current release 913 I see the layout names.
Re: layouts edit
Posted: 27.09.2024, 12:41
giudansky wrote: 27.09.2024, 11:46the layout names in the "edit layout" window don't have names and it's hard to manage them.
For me, if I create layouts, I can name them and the names are visible in the "Edit layouts" window and in the "Define action toolbars" window.
fc Screenshot_09272024_123938.png (12.12 KiB) Viewed 389516 times
Re: layouts edit
Posted: 29.10.2024, 09:31
by giudansky
Nope, still having unconsistency between item names in the layout. It's almost impossible to manage them because they are unlabeled.
Re: layouts edit
Posted: 29.10.2024, 10:32
Have you checked your program version?
Re: layouts edit
Posted: 29.10.2024, 17:18
by giudansky
Sure the last one. I wouldnt complain without the last donor ver. :)
Re: layouts edit
Posted: 02.11.2024, 16:30
It is changed in 916.
Re: layouts edit
Posted: 24.11.2024, 11:45
by giudansky
Perfect. Exaclty what it was missing.
