Recycle Bin could use a pre-cashing feature
Posted: 04.11.2024, 13:39
Almost every time I go to to the overall Recycle Bin system folder FreeCommander freezes significantly. And that is because most of the time I have thousands of deleted items that amount to dozens if not hundreds of GBs. But if I will navigate to a Recycle Bin folder like e.g.
C:\$RECYCLE.BIN\S-1-5-21-3797103458-798797042-3558267449-1001
then even if it holds 99% of deleted items from all of my volumes then they are shown immediately - although as unrecognizable gibberish like for example folder $R1W8WMB or file $ITKY0PH.JPG
And when I use the Recycle Bin icon from the Desktop and thus enter it using Windows Explorer I also get a progress bar for a few seconds - thus I am guessing this is a system depended thing
So would it be possible for FreeCommander to monitor / cache all those Recycle Bin folders so that it could provide user with content of the overall Recycle Bin folder at a moments notice whenever user evokes it - just like when navigating through ordinary folders using FC? I reckon this should be an optional feature because it would either eat RAM resources or would have to relay on some sort of constantly updated database
This slow access to deleted content has been happening to me for the longest time, probably since forever
I am using FreeCommander Build 912 64-bit Donor Portable and Build 901 32-bit Public Installed on Windows 10 Enterprise 20H2 x64 [10.0.19042]
Re: Recycle Bin could use a pre-cashing feature
Posted: 18.03.2026, 22:14
This issue is still relevant in Build 946 64-bit Donor Portable and Build 941 32-bit Public Installed on Windows 10 IOT Enterprise LTSC 21H2 x64 (19044.6691)
Can I have an answer then to my workaround of FC somehow caching the overall Recycle Bin?
Posted: 19.03.2026, 19:52
Opening the recycle bin for the first time takes a long time if it contains tens of thousands of files.
Is the time the same if you open the recycle bin second or third time?
Posted: 20.03.2026, 09:27
I do not remember it if always have been like this, but surely for years thus through multiple Builds and my various personal settings: re-opening after closure is as slow as initial opening
And even if I will open next to each other 2 Tabs with Recycle Bin in either 1 or both Panels and then close the latest one, access to the surviving Tab still takes the same flow-breaking amount of time
Posted: 20.03.2026, 17:47
I have defined a detailed view that allows me to open a $RECYCLE.BIN folder containing more than 20,000 deleted items in under 2 seconds.
Unfortunately the detailed view must be defined directly in the freecommander.ini.
I have defined the detailed view with the name "Recycle.Bin".
In the section [FcDetailedViews] add on the last position the line with Recycle.Bin.
[FcDetailedViews]
1=xxxx
2=xxxx
3=xxxx
4=xxxx
n=Recycle.Bin
Copy and paste the whole section below after the last line in the section [FcDetailedViews].
[FcDetailedViews_Recycle.Bin]
LoadShellTitle=1
Condition=<sub>?:\$RECYCLE.BIN\*
ShowExtensionInCaption=1
ItemsCountRecursive=0
SizeCountRecursive=1
LastSorting=0,0,-1,0
AutoSizeNameColumn=0
1col_Name=Name
1col_Format=
1col_Align=0
1col_Width=20
1col_Sort=0
1col_ContentType=0
1col_ShellContentType=0
1col_RefValue=
1col_Content=0
1col_LvIndex=0
2col_Name=File name
2col_Format=
2col_Align=0
2col_Width=28
2col_Sort=0
2col_ContentType=1
2col_ShellContentType=0
2col_RefValue=
2col_Content=167
2col_LvIndex=1
3col_Name=Origin
3col_Format=
3col_Align=0
3col_Width=44
3col_Sort=0
3col_ContentType=1
3col_ShellContentType=0
3col_RefValue=
3col_Content=1
3col_LvIndex=2
4col_Name=Deleted on
4col_Format=
4col_Align=0
4col_Width=20
4col_Sort=0
4col_ContentType=1
4col_ShellContentType=2
4col_RefValue=
4col_Content=2
4col_LvIndex=3
5col_Name=Size
5col_Format=
5col_Align=1
5col_Width=12
5col_Sort=0
5col_ContentType=0
5col_ShellContentType=1
5col_RefValue=
5col_Content=6
5col_LvIndex=4
In the UI under Settings->View->Column profiles: move the added "Recycle.Bin" detailed view at the top.
You need additional an reusable filter with the name e.g. "Recycle.bin $R items".
The definition of the filter need only value for "Include" field: $R*
You can simply use the quick filter too: $R
You can define button in the toolbar for the filter or you can use it for the automatic view.
Now if you open e.g. D:\$RECYCLE.BIN\S-1-5-21-3777255868-3057126717-2516846410-1001 and set the filter "Recycle.bin $R items" the right content is showed.
Posted: 21.03.2026, 10:24
Before I indulge in this:
I already have some Detailed Views set-up
[FcDetailedViews]
1=POGO 2.0.1
2=Recycle Bin
3=This PC
4=MXD 1.0.0
My 2nd block of settings is this
[FcDetailedViews_Recycle Bin]
LoadShellTitle=1
Condition=<pidl>::{645FF040-5081-101B-9F08-00AA002F954E}
LastSorting=1,0,0,0
1col_Name=Name
1col_Format=
1col_Align=0
1col_Width=177
1col_Sort=0
1col_ContentType=1
1col_RefValue=
1col_Content=0
1col_LvIndex=1
2col_Name=Date Deleted
2col_Format=
2col_Align=0
2col_Width=26
2col_Sort=0
2col_ContentType=1
2col_ShellContentType=2
2col_RefValue=
2col_Content=2
2col_LvIndex=0
3col_Name=Original Location
3col_Format=
3col_Align=0
3col_Width=70
3col_Sort=0
3col_ContentType=1
3col_RefValue=
3col_Content=1
3col_LvIndex=2
4col_Name=Size
4col_Format=
4col_Align=1
4col_Width=16
4col_Sort=0
4col_ContentType=1
4col_ShellContentType=1
4col_RefValue=
4col_Content=3
4col_LvIndex=3
5col_Name=Date modified
5col_Format=
5col_Align=0
5col_Width=24
5col_Sort=0
5col_ContentType=1
5col_ShellContentType=2
5col_RefValue=
5col_Content=5
5col_LvIndex=4
And it works like I want it to work (except for slow load up when tens of thousands of items are in it)
So my questions would be:
#1] Why would I be using
i.e. what is this >>645FF040-5081-101B-9F08-00AA002F954E<< coded string?
#2] Why does it have up to
5col_
entries? Why not just one
col_
i.e. why there are 5 iterations? I currently have 8 volumes in my system, so if anything I would be expecting this going up to
8col_
#3] Can implement your solution to this Detailed View of mine i.e. adjust it, so that I would not have to start from scratch?
#4] Is your solution achievable only by mingling with the INI file i.e. there are no sufficient options in the GUI for achieving this caching?
Posted: 21.03.2026, 11:59
You can see it in the section title: Recycle bin. It is Windows path for Recycle Bin. Simply paste "::{645FF040-5081-101B-9F08-00AA002F954E}" in the Windows Explorer address bar.
Why does it have up to 5col_ entries? Why not just one
Simply check the detailed view in the UI and you will see. What could be for "col"?
You do not need start from scratch. You have a ready-made solution. Your detailed views will remain and are unrelated to the new one.
I already wrote it in my topic.
Posted: 23.03.2026, 10:10
Forez wrote: 21.03.2026, 10:24 [...]
5col_
entries?
Marek wrote: 21.03.2026, 11:59 Simply check the detailed view in the UI and you will see. What could be for "col"?
So those settings that are governing their Columns
Posted: 23.03.2026, 11:19
As for your instructions
Marek wrote: 21.03.2026, 11:59 [...]
I simply had trouble understanding them
In my
FreeCommander.ini
main config file I have now
[FcDetailedViews]
1=Recycle.Bin
2=POGO 2.0.1
3=Recycle Bin
4=This PC
5=MXD 1.0.0
and below this block the next first block now is that yours
LoadShellTitle=1
1col_Name=Name
1col_Format=
1col_Align=0
1col_Width=20
1col_Sort=0
1col_ContentType=0
1col_RefValue=
1col_Content=0
1col_LvIndex=0
2col_Name=File name
2col_Format=
2col_Align=0
2col_Width=28
2col_Sort=0
2col_ContentType=1
2col_RefValue=
2col_Content=167
2col_LvIndex=1
3col_Name=Origin
3col_Format=
3col_Align=0
3col_Width=44
3col_Sort=0
3col_ContentType=1
3col_RefValue=
3col_Content=1
3col_LvIndex=2
4col_Format=
4col_Align=0
4col_Width=20
4col_Sort=0
4col_ContentType=1
4col_RefValue=
4col_Content=2
4col_LvIndex=3
5col_Name=Size Auto
5col_Format=
5col_Align=1
5col_Width=12
5col_Sort=0
5col_ContentType=0
5col_RefValue=
5col_Content=6
5col_LvIndex=4
I also went to
Main Menu > Folder > Filter > Set filter > Reusable filters > Define > General > Add new filter (Ins) [ICON]
and created a new Filter named
Recycle.bin $R items (cache test)
And then I set-up for it in the
Main Menu > Folder > Filter > Set filter > Reusable filters > Define > General > Include
box that
$R*
expression and also chosen for it the
Main Menu > Folder > Filter > Set filter > Reusable filters > Define > General > Apply for > Files and Folders
option
But now what I am suppose to do?
Is this now usable by various means? By such 4 methods?:
A] Manually write
$R
in Quick Filter box, then activate it and then finally go to Recycle Bin folder by whatever means?
If yes, then it does not seem to speed up showing of items in Recycle Bin. Plus I need then to manually turn off the Quick Filter or delete its expression
B] Manually choose the
Main Menu > Folder > Filter > Recycle.bin $R items (cache test)
and go to Recycle Bin folder by whatever means?
If yes, then I have doubts if it works correctly. Because sometimes both Panels automatically switch paths in one or both of my Active Tabs to Recycle Bin of the volume a given Tab is already exploring, while most of the time it would just apply to current path(s) in Address Bar(s) the color I had chosen for Filter. But all in all e.g.
T:\$RECYCLE.BIN
shows up as being empty folder (just like every other local Recycle Bin). Plus I need then to manually turn off the Filter
C] Add an icon to a Favorite Toolbar that opens Recycle Bin folder and only after clicking that icon execute method A or B?
If yes, then I already have twin
[Tools2054_Recycle Bin ● Left]
Category=
Prg=C:\QQ\FreeCommander\FreeCommander.exe
Dir=
Par=-T -C -L=::{645FF040-5081-101B-9F08-00AA002F954E}
DosFormat=0
UseDoubleQuote=1
DelimiterChar=
IconFile=C:\QQ\! ICONS\folder system Recycle Bin.. Full.ico
IconNr=0
HotKeyNr=-1
GHot=0
WinState=0
ShowInMenu=1
ShowInToolbar=1
RunAs=0
RunSeparate=0
WidthPixel=0
[Tools2054_Recycle Bin ● Right]
Category=
Dir=
Par=-T -C -R=::{645FF040-5081-101B-9F08-00AA002F954E}
DosFormat=0
UseDoubleQuote=1
DelimiterChar=
IconNr=0
HotKeyNr=-1
GHot=0
WinState=0
ShowInMenu=1
ShowInToolbar=1
RunAs=0
RunSeparate=0
WidthPixel=0
in my
FreeCommander.fav.ini
sub-config file - is it then correct / compatible?
D] Add in
Tools > Settings > View > Column profiles / Automatic views / Auto selectable views >
a proper entry - which will make the Filter be applied automatically whenever / however I navigate to Recycle Bin?
If yes, then this is a method that seems being convenient enough to be enacted by me, because it does not require additional manual steps. But how would it need to look like? I already have
[asv_300B4EAA-5116-43F6-AEC2-C580E032636C]
Id=300B4EAA-5116-43F6-AEC2-C580E032636C
Name=Recycle Bin (an Auto Selectable View)
ViewStyle=2
DetailedViewName=
DetailedViewAutoSelect=1
SortColumnContentType=1
SortColumnContent=2
SortAsc=0
SizeOfFolders=0
ContentConditionType=0
ContentCondition=
QuickFilter=
QuickFilterBehave=0
FilterId=
in my
FreeCommander.views.ini
sub-config file
Posted: 23.03.2026, 19:09
1. Define reusable filter; In my list it is the filter number 3
screen_2026-03-23 18-14-10.png (22.63 KiB) Viewed 154777 times
2. Add reusable filter 3 to the e.g. splitter toolbar
3. Open the recycle bin folder in the left/right panel, e.g. D:\$RECYCLE.BIN\S-1-5-21-3777255868-3057126717-2516846410-1001 and click the button for reusable filter on the splitter toolbar
Posted: 24.03.2026, 20:33
I do it think we are on the same page here
First you say that
Marek wrote: 20.03.2026, 17:47 I have defined a detailed view that allows me to open a $RECYCLE.BIN folder containing more than 20,000 deleted items in under 2 seconds.
but then that
Marek wrote: 20.03.2026, 17:47 [...]
and repeat that also in the latter post by saying
Marek wrote: 23.03.2026, 19:09 [...]
This implies I have to first open Recycle Bin, which now takes me 6 second because it hold 55000 items at the moment, wait for it to actually open all the way in and thus give me control - and then I need to manually activate the Filter, which takes 4-5 seconds. Where is the gain in this?
What I need is a way to somehow open or at least re-open Recycle Bin with its content being preloaded, so that I will never (or just once during a session) have to wait e.g. 6 seconds
As for that Filter itself, like I wrote in this post viewtopic.php?p=44551#p44551, I do have set it to Include
$R*
And all it does when activated is narrowing down those 55000 items to show 1 extensions-less file named
$REVISION
Posted: 25.03.2026, 21:36
I'm sorry if that didn't work for you. If your current method for opening of the recycle bin is better and faster, then continue using it.
Posted: 26.03.2026, 08:25
All in all, right now there is no persistent cache function in FreeCommander, not for Recycle Bin nor for ordinary folders, right?
But will it be added in a foreseeable future?
Posted: 26.03.2026, 09:24
No such plans.
Posted: 26.03.2026, 09:43
So it seems that in this matter I just must continue supplementing usage of FreeCommander with Everything
