Build 920: My old defined Keyboard Shortcuts couldn't be used with english.lng
Bugs and issues.
Re: Build 920: My old defined Keyboard Shortcuts couldn't be used with english.lng
#16 Post by Marek » 01.01.2025, 20:00
Have you tried to start FC as Admin?
Is the icon of the FcContextMenu64 in sytem tray visible?
Do you have multiple monitors? Maybe the context menu appears on wrong monitor?
As a test, you can disable the 64-bit context menu and then check if the native 32-bit context menu appears (FcContextMenu64 is not used).
For disabling add in the freecommander.ini (Freecommander must be closed) the following line:
[Form]
ShowContextMenu64Bit=0
In the tree FcContextMenu64 is not used - only 32 bit context menu is showed.
antoine
#17 Post by antoine » 01.01.2025, 21:12
Marek wrote: 01.01.2025, 20:00Have you tried to start FC as Admin?
Yes. When launched as Admin, FreeCommander has the same behavior (context menu in the Tree pane but not in the File/Folder list).
Marek wrote: 01.01.2025, 20:00Is the icon of the FcContextMenu64 in sytem tray visible? Do you have multiple monitors? Maybe the context menu appears on wrong monitor?
The FcContextMenu64 icon is not present in the system tray.
I just have one monitor (3840x2160 resolution).
Marek wrote: 01.01.2025, 20:00As a test, you can disable the 64-bit context menu and then check if the native 32-bit context menu appears (FcContextMenu64 is not used).
[Form]
I proceeded as advised. Although I could see the difference (font size in the file/folder list view changed), the issue still remains : context menu works fine in the Tree pane but not in the File/folder list view.
#18 Post by Marek » 01.01.2025, 21:35
Have you checked multiple view types: list, details, thumbnails?
Have you checked in maximized and normal mode?
Could you additional to ShowContextMenu64Bit=0 rename the file FcContextMenu64.exe.
#19 Post by Marek » 01.01.2025, 22:17
Could you check your Settings folder if the file FcExceptionLog.txt exists?
If yes, could you send me the file?
antoine
#20 Post by antoine » 01.01.2025, 23:12
Thanks a lot Marek for your help.
Marek wrote: 01.01.2025, 21:35Have you checked multiple view types: list, details, thumbnails?
I checked ; my default view is "details" and switching to other views (list, thumbnails) did not change the behaviour.
Do you mean switching to fullscreen (F11)?
This led to a change. Now I can see a context menu in the file/folder list view. Yet, it is not the "usual" context menu. Typically the context menu does not include "Scan with Windows defender" entry as an example.
I don't have any FcExceptionLog.txt file in the Settings folder.
antoine
#21 Post by antoine » 05.01.2025, 12:57
Hi all, any idea about a way I could fix my "context menu" issue? Thanks in advance.
#22 Post by Marek » 05.01.2025, 15:44
You could check if one context menu item block display.
You could use the tools from nirsoft.net: http://www.nirsoft.net/utils/shexview.html, http://www.nirsoft.net/utils/shell_menu_view.html
Disable all not Microsoft items and check if the context menu is displayed.
antoine
#23 Post by antoine » 05.01.2025, 16:12
Thank you Marek.
As per request, I disabled all non-Microsoft context-menu entries via ShExView and ShellMenuView: no change at all.
I really do not understand what's going on. Even the context menu launched via Shift+F10 is not the usual one.
I made screenshots comparing the Context menu (for a .jpg file) displayed via SHIFT+10 in FreeCommander, in Win11 native file explorer and in DoubleCommander (please see below).
I also sent you a private message.
http://emeris.free.fr/capture_fc.jpg
#24 Post by Marek » 05.01.2025, 16:21
In FreeCommander have you ShowContextMenu64Bit=1 and FcContextMenu64.exe exists in program folder?
After disabling the menus with nirsoft, try to restart your PC.
antoine
#25 Post by antoine » 05.01.2025, 16:44
Marek wrote: 05.01.2025, 16:21 In FreeCommander have you ShowContextMenu64Bit=1 and FcContextMenu64.exe exists in program folder?
* I do have a "FcContextMenu64.exe" file in FC program folder.
* Regarding the .shc file, whether I set : [FORM]ShowContextMenu64Bit=1 or [FORM]ShowContextMenu64Bit=0, it does not change anything : the context menu is not displayed via right-click
* For your information, if I rename "FcContextMenu64.exe" in something else e.g. "none.exe" then, whatever the ShowContextMenu64Bit=0 or 1, I get an error message "Programme not found" when right-clicking.
Testing now the Nisoft tools with reboot.
antoine
#26 Post by antoine » 05.01.2025, 16:58
antoine wrote: 05.01.2025, 16:44 Testing now the Nisoft tools with reboot.
That was it. As per recommendation from Marek, I disabled all non Microsoft context-menu entries via both Nirsoft tools, rebooted, enabled them all back again, rebooted and... it seems to work.
The context menu seems to work fine again (with the "Scan with Windows defender" entry).
Thanks A LOT Marek for your help.
#27 Post by Marek » 05.01.2025, 17:19
Great that this works now.
[FORM]
should be in the freecommander.ini and not in the freecommander.shc
antoine
#28 Post by antoine » 05.01.2025, 18:32
Marek wrote: 05.01.2025, 17:19 [FORM]
Sorry, my bad. For your information, my freecommander.ini did not contain any setting for "ShowContextMenu64Bit".
I set "ShowContextMenu64Bit=1" just in case.
Users browsing this forum: No registered users and 707 guests
