Could you please add an item to minimise to the system tray, it would be particularly useful when running a very long copy/synchronize routine (one that takes days).
And on the subject of synchronization, there isn't a clear copy only option to compare and then only copy over the changes and additions. Maybe it's just the Copy command, but having the option displayed with the sync option, too, if that's the case, would make things a lot more intuitive.
Aldo downloaded the chm file, but not sure how to open it from within the file commander app. I can't find any instructions on how to install it. I'm probabaly being exceptionally dense.
Many thanks
Terry Hornsby
Minimise to the system tray
Re: Minimise to the system tray
Just a workaround, try HotkeyP, command is simple, available in the context menu, or just use:
Any keyboard shortcut can be assigned, it will minimize any window to tray.
Minimize app to tray-
rocco_lampone
..Aldo downloaded the chm file, but not sure how to open it from within the file commander app...
1) click on the help [F1] key, FreeCommander prompts with the folder details where it is looking for the chm file.
2) right click on the path and copy it, paste the (extracted) chm file in that folder.
Next time you click on [F1] key FreeCommander should launch the chm file.
In FAQ you have some advice to download, install help-file and if some problems appear:
4., 5. and 6. topic
https://freecommander.com/en/faq-freeco ... stall-help
4., 5. and 6. topic
Regards
Ralf
Win10 (64-bit), Intel i7-2600 (3,4 GHz), 8 GB Ram, 500 GB SSD, 2x2000 GB HD, NVIDIA GeForce 545
Ralf
Users browsing this forum: No registered users and 7 guests
