Ability to change the locked tabs colours and fonts
Posted: 10.06.2025, 06:24
by stephen147
See this setting. This addition would be nice to distinguish between the locked and unlocked tabs.
Re: Ability to change the locked tabs colours and fonts
Posted: 24.03.2026, 00:03
And what exactly it is that you are proposing?
Except for colors / fonts used personally by me, I do not see a difference between Settings present in my menu and those visible on your screenshot
Posted: 18.04.2026, 01:40
by stephen147
Colours for locked and unlocked tabs as I've mentioned in the post. Currently there's no option to distinguish between unlocked and locked tabs.
Posted: 18.04.2026, 14:17
For now, the closest workaround you can achieve is to use a block character like
for the option of
Tools > Settings > View > Folder > Folder Tabs > Tab Management > Mark locked tabs with this character
Posted: 18.04.2026, 20:54
Another possible workaround, I'm using too:
Use (big) icons for tabs, then assign a custom icon for locked tabs, other - unlocked tabs will use a simple "folder" icon, so it's easy to distinguish them.
It's working if you're using the same locked tabs, not if you lock/unlock the tabs often.
Alternative option, which would not disrupt the color schemes, could be the custom icon for all locked tabs, or for all unlocked tabs - rest would be standard/other custom icons.
Posted: 19.04.2026, 15:39
stephen147 wrote: 18.04.2026, 01:40 Colours for locked and unlocked tabs
If this were to be implemented, then maybe all together with ability to mark adherence to a Tab Group - a new ability I proposed in point #7 of this post of mine: viewtopic.php?t=13824
