Bottom right quick filter - add a folder toggle to filter folders yes/no
Posted: 14.07.2025, 08:40
by kkc
The Quick Filter (Ctrl-Y) in the bottom right of the main pane, within the status bar is incredibly useful (Thank you....!).
It would be really helpful to have a 2nd toggle button that would include/exclude folder names in the filter function output.
Example: lets say I have a filter for ABC, so all files with ABC in filenames are shown. But no folders are shown as this is excluded in Options.
The toggle button would override, and allow folders with ABC in folder name to also be shown - or not shown.
Thanks for listening!
Re: Bottom right quick filter - add a folder toggle to filter folders yes/no
Posted: 23.03.2026, 23:23
But why toggling of just folders?
Instead I propose either 1 icon with 3 state (all items, just files, just folders) - or 2 icons (just files, just folders)
