Context menu for free space in directory same as in windows - possibility in settings?
Posted: 24.07.2025, 13:38
If you click by right mouse button in folder(directory) free space in FreeCommander you got a FC specific context menu where is also one (the second from the bottom) item - the windows context menu.
For me this FC menu is needless. I always need the windows context menu.
Can you set new setting point for FreeCommander - style of context menu for free space in folder - the current FC context menu or directly the windows context menu. The windows context menu contains commands which are needed = new file/folders, Git Clone etc.
Thanks in advance.
Pavel Riha
Thanks in advance.
Pavel Riha
