Navigating between open tabs with Ctrl+Tab unexpectedly change the drive/folder of each tab
Posted: 10.11.2025, 01:21
by Gianni1962PiacenzaIT
Navigating between open tabs with the keyboard using Ctrl+Tab or Shift+Ctrl+Tab
results in the drive/folder displayed in each tab to unexpectedly change to another drive/folder.
This happens if I "press and hold" those key combinations.
- use the default settings
- open several tabs (seven should be enough) and make sure each shows a different drive or folder
- "press and hold" Ctrl+Tab to quickly navigate between open tabs
- release and repeat one or two more times
Result: the tabs no longer show the same drives/folders as before.
Windows 11 Pro 24H2 OS Build 26100.6584 Italian
FreeCommander XE 2025 Build 937 64-bit donor
The latest public version is not affected by this bug.
FreeCommander XE 2025 Build 921 32-bit public
Re: Navigating between open tabs with Ctrl+Tab unexpectedly change the drive/folder of each tab
Posted: 10.11.2025, 21:12
Thanks for reporting it.
It is fixed in the 938.
