set folder tab to show "This PC"
Posted: 03.01.2026, 23:25
by RiffRaff
Hi - sorry I know this must have been answered somewhere but I can't find it. Can someone pls point me in the right direction?
I'm trying to set a tab with "This PC" as the Locked Path.
When I select "This PC" in Tab Properties > Locked Path, FC displays: ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}, which is fine,
but when I save it, the tab reverts to the Desktop, and FC overrides the Locked Path as <CSIDL:0
I've tried setting the Locked Path to: shell:MyComputerFolder with an identical result.
How do I get "This PC" to stick?
Thank you.
Re: set folder tab to show "This PC"
Posted: 04.01.2026, 14:26
Are you using the latest version 940?
Here it works fine after defining and program restart.
Posted: 04.01.2026, 23:23
It works good here too.
FreeCommander XE 2026 Build 940 32-bit, Windows 10 64-bit.
