Build 940 32 Bit, "Copy details to clipboard" file type bug?
Bugs and issues.
ikkyo
#1 Post by ikkyo » 05.01.2026, 22:47
Windows 10 latest with NTFS SSD drive.
FreeCommander XE 32 bit free Build 940.
Tried the "Copy details to clipboard" function on several folders.
File/folder list has "Name", "Size Auto", "Modified", "Created", "Type", and "Attribute" columns.
Sooner or later the "Type" values copied to clipboard are just "File" even if FreeCommander shows the correct Type value in the File/folder list.
It seems like more than 150 files (or files and folders?) are required to trigger this issue.
The number up from which file it turns to be "File" seems to be fix, if all are the same type like pictures named like IMG_2318.JPG and "IrfanView JPG File" type in my case.
Tried in portable version it was 37.
In the installed version it is 24.
It also seems to depend on file names, but I do not see a logic, for some it is correct, for some not (not necessarily the last ones in the list).
Seems to be a very special one.
Regards
Users browsing this forum: rockstar247 and 74 guests
