940 + Win11 (25H2): right-click on RAR does not populate WinRAR in popup menu
Posted: 20.01.2026, 12:10
WinRAR (v7.13 64-bit) installed, shell extension implemented.
so that it supposedly appears in right-click popup menu on RAR file.
And in Win11 (25H2) File Explorer, right-click on RAR file does show WinRAR at the very bottom of the primary right-click popup menu. Note it does seem to populate that WinRAR item at the bottom, after the main top portion of the File Explorer primary popup menu completes. This may have something to do with how WinRAR inserts itself into the Windows shell. This is probably what is causing the problem with FCXE not presenting it on its right-click menu. Also note that PowerISO is NOT shown on this first primary popup menu.
Note that WinRAR also appears up near the top of the Win11 File Explorer secondary popup menu (i.e. if you click on "Show more options"), which produces the classical Win10 version of the right-click popup menu. Also note that PowerISO (which also inserts itself into the Windows shell) appears on this secondary File Explorer menu, but does NOT appear on the original primary menu.
Also note that WinRAR (as well as PowerISO) appears in the Explorer right-click menu when running Win7:
However in Win11 (25H2) using FCXE (940) and right-clicking on a RAR file, FCXE does NOT show WinRAR in the popup menu (although it DOES show PowerISO):
In contrast, in Win7 also using FCXE and right-clicking on a RAR file, FCXE DOES show WinRAR (as well as PowerISO) in popup menu:
Finally, note in the above screenshots that Notepad++ also inserts itself into the Window shell. In Win11 its entry only appears in Explorer's secondary "show more options" right-click menu, not in the primary first right-click menu. And using FCXE the right-click menu DOES present Notepad++ from that secondary menu, same as it showed PowerISO from that secondary menu.
So it is only in the handling of WinRAR, which appears (slightly delayed) at the bottom of the primary menu, as well as up at the top of the secondary menu, which appears to be confusing FCXE in its presention of the right-click menu.
