944 - Rename dialog input fields missing
Posted: 03.02.2026, 14:11
by CabbageTree
Hi there!
Thank you for the fresh new version.
The updated Rename dialog is lacking the text input fields. However when resized enough, they appear. I tried to relaunch, reinstall even changing themes. Still the same. (See the screenshots.)
Thanks!
[Windows 11 Home, 25H2 — FC 944, 64, portable]
Re: 944 - Rename dialog input fields missing
Posted: 03.02.2026, 15:47
by Mr-Fly
Same here, first thought the dialog is completely broken but size helps ;-)
Posted: 03.02.2026, 21:33
Confirmed.
FC 944 64-bit, Windows 10
Posted: 04.02.2026, 22:09
Fixed in 945.
Thanks, Marek.
