Auto Size
Posted: 10.03.2026, 23:33
by Ken_Cooper
Running v946.
My usual display has two panels, both showing Tree View
In Left panel, if I select C Drive, the "Size Auto" column shows the Folder Sizes.
In Right panel, if I select C Drive, the "Size Auto" column does NOT show the Folder Sizes.
How can I turn ON the Right Panel to display the Sizes, hence matching what shows in Left Panel... ?
Re: Auto Size
Posted: 11.03.2026, 18:33
From the help
Activating the main menu item "Folder → Size of folders" or the shortcut "Alt+F9" activates/deactivates the determination and display of the sizes of the folders in the active panel.
It means, you should activate displaying the folder sizes for each panel.
Re: Auto Size
Posted: 12.03.2026, 16:38
by Ken_Cooper
Thanks for the suggestion. It worked.
Guess I should use the Menu options more often.. :)
