Search window does not allow for rearranging of all Columns
Posted: 22.03.2026, 11:43
After pressing of CTRL+F, the somewhat new option of
Search files/folders > Options > Search result - columns...
that allows for arranging of Columns does not work fully. And that is because the Name and Found in Columns are not-movable, thus leaving to the user the ability to shuffle only the Size, Modified and Created Columns of that Search files/folders pop-up window
I am using Build 946 64-bit Donor Portable and Build 941 32-bit Public Installed
