Display of file name is broken by filled horizontal pointing triangle signs ◀▶ and ▶◀
Bugs and issues.
#1 Post by Forez » 04.04.2026, 16:07
Usage of precisely
and / or
pack of signs makes name of a file that uses them be truncated at its end with
indication, even if the name is very short
The below screenshot tells it better:
Take notice of how creation of
aaa ◀▶ bbb - Copy.7z
i.e. a system-automatically-named copy of
aaa ◀▶ bbb.7z
healed the original by transferring the glitch to that said duplicate. This also healed the
aaa ▶◀ bbb.7z
I am using Build 946 64-bit Donor Portable and Build 941 32-bit Public Installed on Windows 10 IOT Enterprise LTSC 21H2 x64 (19044.6691)
Re: Display of file name is broken by filled horizontal pointing triangle signs ◀▶ and ▶◀
#2 Post by Marek » 11.04.2026, 12:05
I am sorry, but from your description I do not know where is your problem?
Have you tried the default settings first?
I see no problem if using ◀ and/or ▶ in the file name.
#3 Post by Forez » 12.04.2026, 21:36
I do not know how more precisely descriptive I could possibly report this bug - therefore I will just ask this then:
after unpacking of this archive
arrows test.zip
(2.15 KiB) Downloaded 2802 times
with TXT test samples, does the folder arrows test A display every file in the same way the folder arrows test B does; and / or there is no truncation of any kind occurring, especially indicated by
t...
showing at the end of some of those files?
#4 Post by Marek » 13.04.2026, 11:35
List view, default settings:
#5 Post by Forez » 13.04.2026, 19:38
I also get the same correct result when using default settings
But my personal settings truncate names of files
#6 Post by Forez » 19.04.2026, 15:26
I have pin-pointed the culprit in my
FreeCommander.ini
which is the
FileListFont_Size=
value - assuming I also use
FileListFont_Name=Segoe UI
The truncation happens if the FileListFont_Size value is set above 9 i.e. when the font is 10 or higher, but I can use e.g. 13 without side effects if I delete the FileListFont_Name line
Users browsing this forum: No registered users and 8 guests
