947 - Viewer window possition is not saved (updated)
Posted: 12.04.2026, 18:34
- use FC in window mode
- open any image in viewer window
- place the viewer window anywhere, e.g. to screen corner
- close viewer
- re-open viewer
= result - viewer window is opened in the middle of the main FC window, may be even off screen
EDIT: Same for the Multi rename window, first, window is opened at correct position, then it's moved away.
FC 947 64-bit portable, with default and custom settings, Windows 10 64-bit.
Re: 947 - Viewer window possition is not saved (updated)
Posted: 17.04.2026, 16:32
by Mr-Fly
Same here. Weird behaviour of position and size for viewer and multi-rename.
Also the icon in the top left shows the icon to move away from full size (two little windows icon) and when clicked, nothing happens except icon changes to FUllscreen icon.
It looks like FC "thinks" it is in full size, but it is not.
I am reverting back to 946, as I am using quick view F3 quite often and have to resize every time.
Posted: 17.04.2026, 16:48
Fixed for the next release.
Posted: 27.04.2026, 09:38
by Mr-Fly
Any news on this?
I am still back one release.
Posted: 29.04.2026, 22:58
Fixed in 948, thanks, Marek.
