[fixed]-[947] cancel copy-action quirky
Posted: 16.04.2026, 10:26
by alf5000
this behavior started with [946] and is still here in [947]
Ctrl+C / Ctrl+V invokes the Windows copy action (not FCXE copy dialogue) on my machine.
1) select a large file/folder
2) press Ctrl+C
3) press Ctrl+V
4) press Esc to cancel the copy-action
5) Win copy dialogue disappears for a second or two, BUT then it appears again and copying continues
the third Esc finally terminates the copy-action
Re: [947] cancel copy-action quirky
Posted: 16.04.2026, 19:48
Have you the same with default settings too?
Could you send me your freecommander.ini?
Posted: 16.04.2026, 20:33
by alf5000
yes, pristine FCXE portable (both versions 946&947) also shows this behavior.
it is always pressing Esc exactly three times.
MS file explorer works correctly.
after further investigation I see that the issue started in earlier versions of FCXE (I didn't notice it earlier).
Posted: 16.04.2026, 20:44
That doesn't happen to me. The operation is aborted immediately after the first ESC.
Posted: 16.04.2026, 20:56
by alf5000
i'll try another machine tomorrow - seems there is something fishy with my Win10
Posted: 16.04.2026, 22:55
It looks like a regression, I could reproduce it in older version, but I just can't reproduce it now in 947, Windows 10.
Please try to provide more info and steps to reproduce, so we could try to reproduce it.
Posted: 17.04.2026, 10:31
by alf5000
I tried it on a different Win10 machine with pristine portable FCXE.
the problem exists, but I cannot tell which version started the issues.
deeper reseach shows, that the problem occurs only when the copy action deals with a lot of different files.
I have a Vivaldi Standalone folder, for example (3,16GB with 16500 files in 2700 folders)
1) select folder
2) press Ctrl+C
3) press Ctrl+V
4) the copy process doesn't immediatly start, but Win10 does some work first (presumable "prepare the copy-action" or "collecting data" as I'd call it)
5) press Esc WHILE this "prepare the copy-action" in progress
6) Win copy dialogue disappears for a second or two, BUT then it appears again and copying continues
mind: if the "real" copying has started, then the first Esc will reliably terminate the process.
Posted: 17.04.2026, 16:41
That's it.
I can reproduce it now, fixed for the next release.
Posted: 17.04.2026, 19:44
by alf5000
, glad you found the problem
