948 DoubleClick-Bug
Posted: 18.05.2026, 12:50
FreeCommander XE 2026 Build v946 and v948 64-bit
DoubleClick on office-templates (*.xltx, *.potx; ...) opens the template-file, not a new copy of the template file.
Standard action in contextmenu is "new", second action is "open".
When using contextmenu the correct action ist user.
In explorer doubleClick opens a new copy of the template file.
v945 with same setting (freecommander.ini) does not have this bug.
v946 and v948 have this bug also with new freecommander.ini.
