Favorites "Open In" Behavior Question
Posted: 12.08.2026, 18:14
by CovenStine
I'm not sure if there's another setting I need to change, but the "Open In" field for all my favorites is not working.
I've set all of my favorites to Open In: New Tab (or Tabs for Active/Inactive double favorites), but none of them do- they all open in the existing tab(s).
As I'm typing this the only thing I can think of is that I've been migrating my FreeCommander settings for a while from job to job, PC to PC- so I suppose it's conceivable that my favorites predate the introduction of the Open In field.
Or, I'm Just Doing It Wrong, which is usually par for the course.
Thanks!
Re: Favorites "Open In" Behavior Question
Posted: 12.08.2026, 18:50
by horst.epp
Bug confirmed
Open in new tab doesn't work
Posted: 14.08.2026, 16:37
It appears that this option currently only works via the tree view.
Posted: 15.08.2026, 10:37
Workaround: press CTRL key and click on menu item.
Posted: 15.08.2026, 18:20
by CovenStine
Ok, that's good to know re the tree- I always have 2 sets of tabs and 2 folder trees showing so I never tried that; and I have to kinda contort my hand weird to input Ctrl-click, so I hadn't tried that one either - but that's great!
Thanks for that!
Posted: 08.09.2026, 15:34
by CovenStine
thanks for getting that sorted! Looks to work great in v953.
I wish all devs were so responsive to bugs, you've got a great system and great support, especially with how small your team is.
Be well, ~C
Posted: 09.09.2026, 01:50
by ok1
Please note there is another bug with "Open Favorite in a new tab" using Ctrl/click.
If there is only one tab open it still opens in the current tab the first time you attempt it. Second time it works.
This also happens when opening a drive.
Posted: 09.09.2026, 22:58
by CovenStine
That's weird, it works fine for me to click a favorite in the favorites with the "Open In" boolean set to "New Tab"
Perhaps that's because of the selection being set up to open in a new tab, but it seems to work.
Have you tried Middle Click? That works in places where control-click doesn't open a new tab...
Running Build 953 x64, on Win 11.
