954 - Exception - Recycle bin refresh
Posted: 29.08.2026, 14:51
- use window mode
- add column "Date Deleted" for recycle bin
- in Automatic Views use Sort on "Date Deleted" for Recycle bin
- you should have multiple files in the recycle bin, 200+, deleted in different times
- delete any file
- switch to Recycle bin tab
- focus/select last deleted file
- Ctrl+R to refresh the list
- Repeat the last step 3 times
= result - exception
Marek, if you can't reproduce it, use can use my custom setting, just switch to recycle bin tab and press Ctrl+R several times, or focus the last deleted file and press Ctrl+R several times. I can always reproduce it, just Ctrl+R is needed sometime 2 times, or 3 times, or even 8 times.
FC 954, Windows 10.
- use window mode
- delete any file
FC 954, Windows 10.
