Syncronize is Broken in ver 953
Posted: 23.09.2026, 19:41
by grant_cole12
On trying to sync two folders nothing happens in the version 953, I rolled back to the previous version 950 and all was well?
Regards
Re: Syncronize is Broken in ver 953
Posted: 23.09.2026, 20:11
What you mean with "nothing happens"?
Can you see the synchronize dialog?
Try to describe when "nothing happens".
Posted: 24.09.2026, 00:26
by grant_cole12
Sorry, the dialogue shows but when you hit the compare button nothing happens, we would see the program cycle through the files, nothing like this happens in this version, however as I said if you install the version 950, that was the last version I was using before 953, ihe compare works correctly.
Posted: 24.09.2026, 22:15
Could you record a short video so I can see what's happening there?
Posted: 25.09.2026, 14:47
by grant_cole12
Hi Marek,
It seems I have been made a fool of, I started the recording as requested with version 950, the compare worked as expected. Then I updated to version 953, the re-installation seems to have cured the previous issue, so the glitch must have been my side, I do apologize.
Regards
Grant
