using different date formats in the multi-rename tool
Posted: 25.09.2026, 22:32
is there a way to use the different date formats or partial dates as a variable for multi-rename?
[d]_[n] only adds the current date format specified, however i'd like to have some presets that could use the different codes
ie:
[yyyy]_[mm]_[n]
[yyyy][mm][dd]_[n]
ie:
[yyyy]_[mm]_[n]
[yyyy][mm][dd]_[n]
