New v392 - return to original folder - inconsistent problems
Posted: 12.11.2008, 00:46
by Bearded Kirklander
I have been testing out this fantastic new feature that lets you return to your original folder when you go back up a level, and for the most part it seems to work.
However, I have started noticing some inconsistent "not working" situations, most seem to be happening when the FC program loses focus to another program and I return back to FC.
I will try to document some sort of reproducible scenario but for now, wanted to report it.
I've been working with 3 other apps - Music Match 7.5, Spider Player 2.3.9 and Bonk Encoder 1.0.9. I have been dragging and dropping files from FC to one of those apps and sometimes double-clicking on an MP3 file so that it auto-loads into Music Match 7.5 or Spider Player 2.3.9 (the MP3 file I double-click on loads into whatever program is open at the time).
When I return back to FC, I think the "Parent" folder is still selected, but the file pane looks to have gone all the way back to the very top of the list instead of the entry that is hundreds of lines below as it should.
BTW, I'm using a folder setup that has some with a couple of hundred sub-folders, and one with over 1,000 sub-folders.
Sorry it's not more detailed. I will try to work on that though.
Thank you.
