Clear history on exit?
Posted: 12.11.2008, 10:51
by TsunamiZ
Is there an option to clear history on exit?
Posted: 12.11.2008, 12:53
You did not start probably the program ever? Otherwise you would notice some things themselves.
Open the Settings and check the option "Delete history entries on close".
Posted: 13.11.2008, 01:55
Yes, checking the setting at least briefly would help you (and us a bit
If I can't find something in any program, I check all settings (BTW this is the first thing when I start a new program - it's so exciting..), then I chech the Help (I know FC's Help is a bit outdated), then search in the forum and then ask in the forum.
Please don't take this as offence, it's just a hint.
