hello all,
i'm not sure if my subject is clear enough, but what im trying to do is place all the plugins inside freecommander portable, im looking for a command so when i move the freecommander portable folder to another computer, i dont need to change the locations of each plugins. i tried using %freecommanderportable%\app\FreeCommander\PLUGINS\wlxTxt_INI.Editor_1.1\IniEd.wlx but it doesn't work. i also tried %FcSrcPath%.
or let say, my current folder where plugins are located
at
C:\Documents and Settings\<user>\Desktop\Folder A \FreeCommanderPortable.exe\Plugins\<plugins.wlx>
if i move Folder A to say Folder B, freecommander should still be able to run the plugins, but i dont know what the command location for this.
so
i moved it to C:\Documents and Settings\<user>\Desktop\Folder B\Folder A \FreeCommanderPortable.exe\Plugins\<plugins.wlx>
i will get not found in the plugins or The system cannot find the file specified in applications, this applies to favorites and viewer applications.
thanks
How to set a permanent command location for plugins?
dudekracked
Users browsing this forum: Amazon [Bot] and 5 guests
