Program Window not coming to foreground when it should
Posted: 29.11.2008, 22:14
by Bearded Kirklander
I'm using v392 Beta with Windows XP SP2.
I've noticed that when the FC window is in the background, it does not always come to the foreground when I click inside of the window.
For instance, if I click inside of a file pane, it may not come to the foreground, but it will if I click on the "Application Title Bar", which is at the very top of the program window and where the minimize, maximize and end buttons are located.
With the other Windows programs that I use, they always seem to come to the foreground if I click anywhere inside of the program window.
But Free Commander does not, and I cannot seem to find an obvious pattern to duplicate the glitch.
Perhaps the program eventually loses track of a certain setting or variable somewhere along the way, I'm not sure.
But I did want to report it because it does seem to be a bug.
