Sort order transfer to explorer sort order.
Posted: 09.03.2009, 14:40
by louiscar
I don't know whether this is possible but it would solve an issue that many people have with picture viewer such as Picasa etc.
eg. Picasa picture viewer will view pictures in a folder in the order that Explorer sorts them. It ignores the way filecommander sorts them. So for instance, if you've sorted your folder by date in an explorer window and by name in filecommander, the viewer will display all files in date order.
Is it possible for filecommander to set explorer's sort order when it's sort order is changed (optionally or otherwise)?
I'm not sure how many viewers out there follow this but those that use Picasa viewer have been totally confused by the behaviour of the viewer because they've not understood why they are getting a seemingly nonsensical order to their picture order which is displayed correctly in FC.
It would be a nice feature to add.
