RUN Command Line always on top
Posted: 06.04.2009, 13:30
by christofc
Is there a way to have the Run Command line as favourite (always on top) / atleast to have short-cut to RUN command line.
Thanks and REgards,
Chrisot
Posted: 06.04.2009, 13:58
by ralfso
Help >>> keyboard shortcuts
DOS Prompt
Toggle between command line and current window - Ctrl+Shift+Spacebar
Run Command as an icon in the freecommander tool bar
Posted: 07.04.2009, 06:33
by christofc
can we have Run Command as an icon in the freecommander tool bar
Posted: 08.04.2009, 00:20
by clanman
You have two options and they are both on the Extras toolbar
The first is the run command which simply calls the Windows Run dialogue box (windows start menu then run). There is no standard FC shortcut for the Run box as Windows has one of Win+R however this does not stop you from creating one under Extras->Keyboard shortcuts.
The second is is DOS box which starts a Dos window in the FreeCommander current folder. The standard shortcut for the Doss box is Ctrl+D
