function key bar: displays incorrect shortcuts when remapped
Posted: 16.04.2009, 01:16
by oddiofile
If I remap the "Copy" to something other than F5, and then I map "refresh" to F5, I still see F5 as the keyboard shortcut for "Copy" in the function key bar.
If I remap it to something else, I'd expect to see the correct binding in the function key bar.
Posted: 17.04.2009, 00:39
You need to restart FreeCommander.
define shortcuts - "ok" without first clicking &qu
Posted: 17.04.2009, 01:03
by oddiofile
after I set a shortcut, if I click "ok" without first clicking "save" I lose my bindings. This is very confusing, especially since i have "auto-save settings".
I would think that if I have that checked, then it should also implicitly "save" settings when I click "ok" from the define shortcuts pane.
Posted: 18.04.2009, 01:38
I know it's a bit confusing, I have already requested to change it. Anyway, it's in the FAQ (you should read before posting).
