New to FC - have a few questions...need expert help!
Posted: 15.05.2009, 06:57
Hello all.
I hate to admit that I just yesterday found FC and now I've been wondering where it's been all my life! I love the program!
I'm pretty picky about my setup, however, and am running into a few things that I don't yet know how to do - or whether or not FC can do them. While I have a few PC's - 2 laptops, 1 desktop - I mainly use my notebook which has a 1280 x 800 screen resolution (13.1 inch). In other words...not a lot of screen real estate.
That said...on to my questions:
http://www.lookpic.com/files/My_Explore ... Setup1.jpg
I've been using the free version of another Explorer replacement program but I'd rather switch over to FC full-time as it kicks major booty over the other one.
My apologies if I've missed any answers to my questions that may already be noted in the forum. I looked through each page and didn't see anything specific to my questions. I also apologize for the length of my post.
Thanks in advance for your help - and thanks for a fantastic program!
- ~ Can the toolbar items be moved from one toolbar to another? For example, can I move items from the "Edit", "Folder 1" and "View" toolbars to the "File 1" and/or "File 2" toolbars to create one or two "master" toolbars consisting of all my preferred functions? I realize the toolbars are named specific to their contents and actions - but this is honestly the first program I've run into where I couldn't add or remove items to/from a toolbar using a master list of all available functions.
- ~ Another toolbar question - is there a way to add more dotted line separators if/when needed? I'm referencing the "-----------" separators in case you're wondering what I mean.
- ~ Now, a question regarding the "Tree" navigation area. I prefer to use FC in the vertical view setting. However, I like using the 'tree' navigation area for both panels (left and right). Is there a way to use one tree on the far left side while allowing it to control both panels - whichever one is the 'active' panel?
- ~ Is there a way to have different background colors for the 'active' and 'inactive' panel (file list) backgrounds?
- ~ Finally, is there a way to configure the Tree so that it looks similar to the one in the image shown after clicking the link below? In other words, if I want to jump to my desktop by using the Tree, is there a way to have a 'Desktop' item at the top of the tree (see image)? I guess I've gotten used to seeing it that way since the standard Windows Explorer shows it that way as does most other Explorer replacement programs.
