Universal (Un)Pack button
Posted: 27.10.2007, 17:44
Universal (Un)Pack button - for the splitter and main toolbar (pack for files/folders, unpack for archive files only) - with the following sub-options:
+ For pack:
- Add to <file name>.zip
- Add to <file name>.zip - to other pane
- Add to archive file (to open pack dialog)
+ For uppack
- Extract here
- Extract here - to other pane
- Extract here, to <archive name>
- Extract here, to <archive name> - to other pane
- Extract to... (to open unpack dialog)
- Open archive (in default archive program)
+ Option in Settings - to select default action for the main button (for both, pack and unpack), so e.g. "Add to <file name>.zip" for pack and "Extract here" for unpack - or any of above.
Explanation: [ [(un)pack]* | [v]** ]
* = main universal (un)pack button
** = sub-button to show menu of sub-options - listed above
+ Customizable keyboard shortcut for the default action.
If this feature would be implemented (and support for 7-Zip archives will be added), I could even uninstall my archive program. :)
