Ctr+Arrow when renaming folders in the directory tree
Posted: 15.10.2009, 00:55
by luispirela
FreeCommander 2009.02 on Windows XP SP3
When renaming a directory in the directory tree (by hitting F2 and getting editting abilities on the directory name itself, if I try to move the cursor word by word, the following happens:
If I use Ctrl+Left_Arrow, the current the tab on the left panel changes to point to the directory pointed by the front tab on the right panel.
If I use Ctrl+Right_Arrow, the current the tab on the right panel changes to point to the directory pointed by the front tab on the left panel
In both cases, both panels end up on the same location.
This does not happen when editing file names, since it opens a dialog box.
