keep File and Folder permissions when moving files (Windows7
Posted: 04.02.2010, 14:25
When I use freecommander to move folders from one place to another, often the permissions I end up with at the destination are different from the originals. Is there some way to make sure the permissions are retained (I'm moving from ntfs partition to ntfs partition).
