Print a listing of the files in a map
Posted: 15.02.2010, 15:08
by wimjanse
I cannot find any possibility to print a list of the contents of a map.
I have use d several years TotalCommander, which had this option
Ie if I want to know what files are on a CD, I go to this CD in one pane, and then I'd like to print the
listing.
If this option is not yet there, would that not be nice for a future update?
Wim
Re: Print a listing of the files in a map
Posted: 20.02.2010, 03:46
by Wiley
I don't see a menu item or button that totally automates a directory printout. However, you can get the job done from within FC by use of the menu item "Folder | Make folder list" and whatever text editor you prefer. It works quite well.
Posted: 20.02.2010, 08:04
You can add it to the toolbar.
