Zip files
Posted: 12.03.2010, 22:45
Power Desk 7 shows zip files as a folder in the left tree pane and when you click on the folder shows the contents in the right pane. Does Free Commander have a similar capability?
You can view the contents of a ZIP or RAR file as you do in Power Desk, but to my knowledge you cannot perform a drag-and-drop of the individual files within the archive. However, a "right-click | Copy" on a file opens a dialog that lets you unpack the file(s) and move it/them to another location. By far, FC's method is not as handy as Power Desk's.king12 wrote:Power Desk 7 shows zip files as a folder in the left tree pane and when you click on the folder shows the contents in the right pane. Does Free Commander have a similar capability?
