Same (false) size of two neigbouring folders
Posted: 02.11.2007, 19:00
Windows XP
Bug noticed in FreeCommander 2007.10.
Reinstallation (with deletion of config file) of version 2007.5a - same bug.
Following picture shows the situation in two steps.
1. Space pressed on the first folder to count folder size.
2. Space pressed on the second folder - both folders are shown with the size of the seccond folder.
Ssimilar situation with using Alt+F9. Some neigbouring folders share common size (correct only for one of them).
This is my first bug report. Hope I didn't blew it.
Image will follow soon.
