Expanding the folder tree
Posted: 23.04.2010, 15:19
by tfor
Hello @ all,
I'm just starting with FreeCommander and I'm looking for a function that I use very often, namely expanding the folder tree with one keypress (the * in Win Explorer).
Searched the Help, FAQ, Menus, shortcuts and this forum, no answer.
Have I overlooked something?
Regards,
tfor
Re: Expanding the folder tree
Posted: 23.04.2010, 16:53
by H.Seldon
Try right-arrow (expand) and left-arrow (collapse).
Posted: 26.04.2010, 13:54
by tfor
The right arrow only expands one level, not the whole tree.
Expanding the whole tree is what I need.
Posted: 27.04.2010, 08:10
by granny
SHIFT + Num* (use the number-pad asterisk)
this will fully expand the tree under the currently selected folder.
If you happen to have C:\ drive selected, you better have a really, really, really fast computer, or else do it while you take a coffee break. It takes a long time to expand for several thousand sub-sub-sub-folders.
Posted: 27.04.2010, 10:55
by tfor
Thanks a lot, that shortcut does the job.
I browsed through the shortcut list again to see if I overlooked it in the first place but it does not seem to be on the list.
Anyway, it's great that it's already implemented and ready to use.
Posted: 28.04.2010, 04:57
by granny
It's actually a standard Windows hotkey, like Ctrl+ C to copy, Ctrl+V to paste.
Just not very well known. I wish it was a command in FC, then we could map our own key combinations.
FC utilizes a lot of Windows hotkeys, but some others have been converted to launch unique FC commands.
