Alt+F2: doesn't change to the folder like in other panel
Posted: 08.06.2010, 14:21
If I have in both panels the same drive, but different folders and I want to set the same folder in both i do the following:
Alt+F2 (if the first panel is active), then the same drive letter as before (for example C). the path in the inactive panel is unchanged. It works if I inbetween switch to the other drive (for example D): Alt-F2 D Atl-F2-C
I use FreeCommander Version: 2009.02a, Windows XP SP3
starting the freecommander using C:\TEMP\Programme\FreeCommander\FreeCommander.exe /N /NewIni=FreeCommanderTest.ini /NoPlugins /Lng=English
