Template Library Pane (similar to XY's Catalog) below Tree
Posted: 29.06.2010, 02:13
by akarich
First up, great product. I'm still on XP and have been using Explorer ++ for a while but have recently switched to FreeCommander because of the additional features. The Quickveiw function is great!!!
What would be great would be a customisable bookmark / catalog pane similar to that implemented in XYplorer or CubicExplorer. For added functionality if it could also work like a drag and drop library that would be great. So you could have all your file and folder templates (documents, dummy folders, spreadsheets, etc) directly accesible and dropable into your active directory view. Might need to allow for custom user script for the copy function so it can handle the *.dotx, *.dot, *.xlt, etc template files.
This would be very handy for project work. And particularly useful for companies with set project directory standards...
