[Solved]R514 - Pack files -> use current folder -> Listbox
Posted: 08.11.2010, 12:18
Hi,
run Pack and choose "Use current folder" now the Listbox "Target" is ReadOnly there is no way to change the name of the ZIP-File.
Mark Checkbox "Create one archive per file" and uncheck it, now the Listbox "Target" is not ReadOnly anymore and you can change the name of the ZIP.
As Default it should be possible to change the name of the ZIP when choose "Use current folder".
Note: The state of "Use current folder" is not saved. When open Dialog next time the Checkbox is not checked anymore. The State should be saved I use current folder in 99% of all cases I use Pack.
