freecommander.ini is saving in appdata folder
Posted: 21.03.2011, 04:31
by scruffy
I'm using the standalone version of Freecommander PXE r531 and every time i exit it at uni I get an error message:
Folder is not writeable: C:\documents and settings\<user>\Application Data\FreeCommanderXE\Settings\freecommander.ini
I'm not sure if this is a bug or not, but as far as I can tell I've told it to save the settings in %FcAppDataPath%. Am I missing something?
It runs from a flash drive.
Re: freecommander.ini is saving in appdata folder
Posted: 21.03.2011, 07:34
The app is doing exactly what you told it to do. And you probably don't have write rights for AppData (don't know why).
You would be better off using the %FcSrcPath% variable, so the settings are saved where FreeCommander.exe is (giving the fact that you're using a USB drive).
Hope it helps!
Posted: 21.03.2011, 07:49
by scruffy
Ahh, sorry, it was acting correctly I just was confused about what I told it to do.
Thankyou very much.
Posted: 31.03.2011, 11:21
by dajare
I'm having exactly the problem reported in post #1, but I cannot get FCXE to change my settings: it *always* tries to use %FcAppDataPath%. This is on a networked machine on which I am a "user" without full (only limited) rights to AppData.
Is there a command-line switch for path-to-ini, perhaps? I, too, would like the ini in the same folder as the exe (= %FcSrcPath%).
I'm using build 532, non-installer version. Thanks for any help with this!
Posted: 31.03.2011, 23:20
freecommander.exe /Ini=
Remove freecommander.ini from %FcAppDataPath% and then start FC.
Posted: 01.04.2011, 09:35
by dajare
@Marek - thanks for that! There is now a "\fcxe\.wcx.ini" file saved, strangely (?) with only very few settings:
[fc_internal_zip]
fcZipCompressionMode=6
fcZipEncryptionMode=0
fcZipSfxStub=%FcSrcPath%
fcZipVolumeSize=10 MB
And that's it, no matter what settings I change, save, "apply", etc. Is this expected? (My "FreeCommander.ini" file is almost 500 lines, by comparison!)
At least those error messages stopped!
Thanks for your help!
